Generic Cisco Device shows error
I am having trouble configuring my Cisco devices using the extension. The error in the config page takes me to the logs and events where I get this error:
“Query failed err=read udp” followed by a bunch of IPs and timeout args. The status code shows 38.
What could be the issue for this?
Hi @AmayShah !
Are you able to poll the device from the ActiveGate?
<span>snmpwalk –v 2c –c <em>yourcommunity</em> <em>yourTargetIP</em></span>
Yes, same issue for me  but on a different extension IDRAC and when we check the snmpwalk command everything is working fine. but still same errors.        Query failed err=read udp *******************:161: i/o timeout: Agent(*******:disappointed_face: GetBulk timout args: .1.3.6.1.4.1.674********** : request timeout (after 3 retries) [status code=38]
Ok. I had an issue with large SNMP answer and network packet size (MTU). I had to define a Max. repetitions to avoid timeout:
