Without OneAgent how can we push metrics to Dynatrace .can anyone explain me detail?
could you please let me know which ingestion method we should use?
It’s deepened on what is your use case, can you please elaborate a bit which metrics you want to collect from where and when (i.e. what is the frequent of the collection) ?
My use case is about how to push the metrics from app server to dynatrace ,i am doing it in generic way so it is not specific to app server
If you are dealing with instrumenting your own application, take a look at OpenTelemetry.
If you are looking at application server metrics, you should really go with OneAgent. Is this is the case, why can’t you?
In this case I would use Metrics API - POST ingest data points or as @AntonioSousa suggested Send data to Dynatrace with OpenTelemetry - Ingest custom metrics
HTH
Yos
The challenge is that without oneagent we should push the metrics from app server to dynatrace.
Is there any method or solution ? Can you please let me know any method or solution ?
