I have created a Processing rule to save the the last column of a log entry as a variable “QueueLength” and saved it as a ‘Custom Attribute’.
How to set an alert to notify me when my Custom Attribute is above, say, 10
The below query in Event Extraction did not work:
matchesValue(log.source, “/path/source.log”) and QueueLength>10
You should create a metric, and then you can define an event based on that metric.
Hi @vishnu_kumar
In addition to provided guidance by @PacoPorro
PFA resources:
Advanced use case:
Hoping it helps.
KR,
Peter
Thanks for these documents guys.
This link you shared:
has helped us
Hi @vishnu_kumar
Glad to hear you have sorted it out :wink: :blush:
