How do I get started with the Problems App?
And how does the Problems App help users manage and remediate detected problems?
Initially, the Problems App provides you with a feed of detected Problems, where the active ones are highlighted and marked in red color. A click on one or multiple of the problems opens the detailed view of each problem, giving you all the necessary details for the selected problem so that you can start remediating the issue. The filter on top of the feed helps you to focus on your most critical problems and the default filter allows you to persist this focused filter for your own user.
