How does the default filter work?
Does the default filter allow users to quickly revert to their preferred filter settings?
While the Problem App remembers the last filter state automatically, it can be annoying to return to your preferred filter whenever you explore your problem feed with other filters. Thats why we introduced a persistent filter which we called ‘Default filter’ that you explicitly save. A click on the default filter resets the current filter with your default one so that you save time.
