How do I merge DQL queries together?
I am trying to return some fields from dt.entity.host as well as data from dt.host.disk.used.percent.
However, when I try to append them, I get null values for Utilisation.
Here is my current DQL code:
fetch dt.entity.host<br>| fieldsAdd tags<br>| fieldsAdd entity.name<br>| expand tags<br>| append [<br>timeseries { percent = avg(dt.host.disk.used.percent), used = avg(dt.host.disk.used), avail = avg(dt.host.disk.avail) }, by: { dt.entity.host, dt.entity.disk }<br>| fieldsAdd Utilisation = arrayAvg(percent)<br>| fieldsAdd entityName(dt.entity.host)<br>]
Any ideas?
You could either do a lookup:
| lookup [ fetch dt.entity.host
| fields entity.name, id, tags ], sourceField:dt.entity.host, lookupField:id
or use the entityAttr:
| fieldsAdd tags = entityAttr(dt.entity.host, "tags")
