So I have multiple metrics from SQL data source extn and I need to put them in rows and show the value. I am doing it like below.
But this is pulling data in one single row, instead of two rows. Can you please suggest how to get the intended result. any suggestion is appreciated. Thank you.
timeseries { db_invalid_object = avg(db_invalid_object)} , by: {device}, filter: { device == “a” }
|fieldsAdd HealthType =“DB Invalid Object”
|fieldsAdd db_invalid_object_count = arrayAvg(db_invalid_object)
|fieldsadd current_status = if(db_invalid_object_count==0.00, “HEALTHY”, else: “UNHEALTHY”)
|fieldsAdd db_node= device
|fields HealthType,db_node, current_status,db_invalid_object_count
|join [timeseries { db_invalid_index = avg(db_invalid_index)} , by: {device}, filter: { device == “a” }
|fieldsAdd HealthType =“DB Invalid Index”
|fieldsAdd db_invalid_index_count = arrayAvg(db_invalid_index)
|fieldsadd current_status = if(db_invalid_index_count==0.00, “HEALTHY”, else: “UNHEALTHY”)
|fields HealthType,db_node, current_status,db_invalid_index_count]
,on:{db_node}
