We have two DQL and want to compare both the outputs in single format. Unable to find suitable option.
Please do suggest.
Hi @amita
Thanks for reaching out. Can you please add some more details to your use case?
What data are you querying? How do you want to compare it? What would be a suitable representation for you etc.
Thanks, Philipp
Hey@Philipp
Thanks for responding,
Basically I want to compare metric for different timeframe.
I am fetching data from bizevent(fetch bizevent),currently I am able to
get data for specific single timeframe .
Now I need a tabular output where same metric can be monitored for two release(timeframe).
I also tried creating two seperate DQL for each timeframe, but didnt find way to merge those two column in single table
Here is some highlevel Expected output
| Application_metric_name | Release1(2nd may) | Release2(6th June) |
| Authentication_avg_CPU_usage | 70% | 73% |
@amita thanks for the details.
One way you likely already figured out is putting two separate queries next to each on a dashboard, for example, via a single-value tile.
If you need to merge the result, you could leverage the lookup command as a workaround.
Example query:
fetch bizevents, from:now()-7d
| summarize this_week = avg(toDouble(amount))
| fieldsAdd helper="test"
| lookup [ fetch bizevents, from:now()-14d, to:-7d
| summarize previous_week = avg(toDouble(amount))
| fieldsAdd helper="test"]
, sourceField:helper, lookupField:helper
| fieldsRemove helper, lookup.helper
| fieldsRename lookup.previous_week, alias:previous_week
Kind regards, Philipp
Hey, Philipp
Thanks for quick response,
It worked for me. I am able to fetch metric for two different timeframe.
Regards,Amita
