Hi everyone,
I want to create a difference between two metrics over the time. For example to show the differnece between published and processed queue messages.
How to do this with DQL?
I tried to start with this command.
timeseries {publish_count = sum(dt.service.messaging.publish.count), receive_count = sum(dt.service.messaging.receive.count)}, by:{messaging.destination.name}
| fieldsAdd difference = publish_count - receive_count
| summarize by:{messaging.destination.name}, total_difference = sum(difference)
But this just return null.
Best regards,
Robert
Hello @robert_laurat,
timeseries returns arrays, so publish_count and receive_count are not single values.
Also, empty buckets are null unless you set default: 0.
Try this for the difference over time:
timeseries {
publish_count = sum(dt.service.messaging.publish.count, default: 0),
receive_count = sum(dt.service.messaging.receive.count, default: 0)
}, by: { messaging.destination.name }
| fieldsAdd difference = publish_count[] - receive_count[]
That gives you a
difference array for each destination, one value per time bucket. Dynatrace supports iterative array expressions like this with
I hope this helps you
Hi @MaximilianoML, the default:0 was the trick.
I also tried to explicitly set [] at the calculation, but without success.
Robert
