I’ve been working to create a single value block on a notebook where I’m fetching two different timeseries values that use the same metric. The dimensions on this metric are by environment and region (region meaning the region of an EKS Kubernetes cluster). The trick is that for each value, they both have a distinct region. Here’s my query so far:
timeseries east_count = sum(`custom-metric`, default:0), by:{env, region}
| filter env == "dev"
| filter region == "region-1"
| append [
timeseries west_count = sum(`custom-metric`, default:0), by:{env, region}
| filter env == "dev"
| filter region == "region-2"
| fields east=arraySum(east_count), west=arraySum(west_count)
I am not currently running the difference between the two because I want to see what both values equate to. I would expect by running this query to get a single record with 2 fields, but I appear to be getting two records, each of which have both fields. The records end up coming back like this:
record1: east: 6000, west: null
record2: east: null, west: 6500
Where have I gone wrong here in returning two records rather than a single record?
