How many ActiveGates do I need?
I have 4 networks, do I need 4 ActiveGates? (I’m only considering environment AG)
It depends on several factors, the main ones being:
You should check also the sizing guide at Dynatrace: Hardware and system requirements for routing/monitoring ActiveGates on Linux — Dynatrace Docs
Hi @natanael_mendes,
Are these networks in the same DC? Is it a managed depIoyment? f yes I would use 4 Environment AG, similar to my other clients. I think this is the best practice.
Managed deployments | Dynatrace Docs
But for geo connections you should use Cluster AG.
Best regards,
Mizső
