OneAgent and ActiveGate ratio
Hello
How much agent can bundles one Active Gate?
What is recomended max limit (this information is not in the documentation)
Hello @Mikhail A.
ActiveGate is a component that can help you reduce the number of outgoing connections and traffic. Therefore, if you plan to install more than 100 OneAgents or if you want to manage large-scale Dynatrace deployments in general, you should consider installing at least one ActiveGate. For 1,000 OneAgents, installing an ActiveGate is highly recommended. You don’t need to install all ActiveGates in advance—you can add additional ActiveGates at any time. If you install multiple ActiveGates in the same environment, your OneAgents and ActiveGates will configure themselves automatically to achieve optimal load balancing.
https://www.dynatrace.com/support/help/deploy-dyna…
Babar
Hello
I have already seen Doc
My question - How much Agent can bundles to One Active Gate
If I have 1100 agent than i will need 2 Active gate or one ?
Hello @Mikhail A.
Basically, this is an optional but recommended component because of the characteristics, so for 1,100 you should have 2 ActiveGate instances or even you can have more.
As per the documentation, for 100 OneAgetns you should consider an ActiveGate in your environment but with 1000 OneAgents must have an ActiveGate.
  • e.g. more than 100 OneAgents or if you want to manage large-scale Dynatrace deployments in general, you should consider installing at least one ActiveGate.
  • but for 1,000 OneAgents, installing an ActiveGate is highly recommended.
Babar
If I have 3000 , Servers what is the recommended number of Active gates ?
Any documentation on dimensioning on Active gate and one agent.
Please have a look at the sizing documentation for Linux ActiveGates and Windows ActiveGates. I also recommend to take in consideration high availability and fail-over (i.e. have at least two ActiveGates per zone).
We also have documentation for the sizing of your disks for a OneAgent on Windows or Linux. For information on memory consumption by the OneAgent have a look here.
Sia
Hello, is there any recommendation number of Active gates to handle the agents influenced by factors like hardware specifications, network conditions, and the specific monitoring tasks it undertakes? Eg 8 cores cpu and 16 memory running Windows Server 2022.
Also find this link https://www.dynatrace.com/support/help/deploy-dynatrace/activegate/basic-concepts/when-do-i-need-to-install-an-activegate/?_gl=1*9s41bl*_ga*NjA4MjMxMTE1LjE3MjYxMDg4NzE.*_ga_1MEMV02JXV*MTc0NTM5NDUxOC4xMi4xLjE3NDUzOTQ3MTguMC4wLjA.*_gcl_au*MTc2NTE2NjEyMy4xNzQ1MzgwNjAz broken
There’s no significant difference in this case. If you’re using the Environment ActiveGate exclusively for OneAgent routing, the size or specifications of the servers monitored by OneAgent have minimal impact on the capacity required for ActiveGates. You can refer to the link below for guidance on recommended ActiveGate VM sizing and the number of OneAgents it can support:
