Yes, it’s possible to have 4. However, 4 nodes give you just more processing power and storage. Starting from 5 nodes you increase availability as you can lose 2 nodes.
If we had 9 nodes part of a cluster, would you only be able to lose 2 nodes or 3 nodes?
in a RACK aware setup you should be able to lose 3 or does this apply to 9 nodes standard configuration too? The documentation states a cluster of 5 or more nodes can only lose 2 nodes.
In one rack and one dc you can afford losing max 2 nodes regardless of the number of total nodes.
when you run 3 racks then you can lose entire rack - no matter how many nodes are in a rack - so more than two.
in 9 nodes setup I’d recommend 3 racks deployment with 3 nodes in each - if you can have a physical location distribution eg within 3 AWS availability zones in a region
