How to setup disaster recovery site for Dynatrace Managed
Hi All,
Currently we have Dynatrace managed with 3 cluster node. Now, we need to setup disaster recovery site with one cluster node or more nodes. How do we set it up? Dynatrace documentation is little confusing in this topic.
Hi @Ramanan_16 ,
With 3 nodes, you’re already highly available - meaning you can survive the loss of one node. If you add two additional nodes having 5 in total - you can afford to lose up to 2 nodes in the cluster.
You can also achieve additional fault tolerance by redundancy, splitting the cluster into:
- separate racks - Rack aware managed deployment
- and/or data centers - Premium HA for multi-data centers
In case you want to set up a disaster recovery procedure for the situation of losing more than that, you’d need to look at the backup/restore procedure: Back up and restore a cluster
Hope this helps to start!
Hi Radoslaw,
Thanks for the details. As per the local government rule we need to shutdown the servers from Head office and run the operation in Disaster recovery site for 1 month. As per the documentation 1 node can go down with 3 cluster setup. 2 nodes can go down in 5 cluster setup. If this is the case, then i need to setup 6 cluster node setup.
So that i can keep 3-3 in each location and bring down 3 nodes during our DR activity. But i am thinking why should we add 3 more nodes to cluster in the DR site which will run only for 1 month. Because our environment is very small. Just thinking how best I can do to maintain the High availability of the cluster as well as to reduce the hardware cost.
Commenting for continuous discussion
