How many hits per minutes are supported by Dynatrace API?
Hi Team,
Could you please help me to know how many hits per minutes are supported by Dynatrace APIs, is there any kind of Threshold set for the same.
Heramb Sawant
@heramb_sawant,
The following limits apply:
You have to be careful what to do with an HTTP/429 reply. The more you insist, eventually more time will take to be able to use it again.
