How to change the default Management Zone on Managed OneAgent
Hi Team,
Can you please advise, how can we change the default management zone to “All” . We have set up 20+ management zone and remove couple of them as per application need. After that, we start seeing below error when we access the Dashboard.
Management zone
You have no access to the predefined default management zone selected for this dashboard.
You can set the predefined management zone for each dashboard as follows:
  1. Edit the dashboard
  2. Set the management Zone to the desired predefined one
  3. Click Done to save the dashboard
Thanks you. It worked.
