Any one have any idea to disable all the oneagents belong to management zone via the UI ?
Hello @chuan_sern_wong
You can use the monitoring overview from the settings to disable the hosts belonging to a particular management zone.
Babar
It still need to checked one by one. In any case, I am looking at API to use and enable/disable via tags
Has anyone discovered an easier way to do this?
Can you sent to me the source code of this application vi email.
My email: phamngocxuyen195@gmail.com
Thank so much
This solution is done for Managed installation ? If yes what should I enter in the field Tenant URL ?
If no is possible to modify for use in Managed installation ?
Thank so much
Hello, is this still working? I tested it, but it’s not working on my end. I created the API token and disabled it, but the change is not reflected in the UI
