Hi, I followed all the steps in Dynatrace Blog | Dynatrace news to create a custom process group, but it didn’t work.
Actually, my environment has been gotten problems with CPU consumptions and more than 60% of this resourse usage is taken by “other” process that Dynatrace doesn’t sort automatically. So I created the custom groups, but all the process that I set (like monitoring, backup, etc) is still labeled as “other process”.
Did you make restart of those processes after process group definition?
Hi Sebastian. Thanks for the answer. Now, I restarted both oneagent and some of the personalized process, but all of them is still shown as other process. What a think too strange is the low level of cpu usage by oracle reported and the high cpu usage by these “other process”".When I see the resources consumption locally in the OS, I got a higher usage for Oracle, specially for the clients and web/application server connections that aren’t local.
Rise support ticket than. This has to have some explanation
This just means the consumption is still by a process that is not being directly known.
For CPU or RAM usage Dynatrace shows just known processes and everything else is “Other processes”. Including kernel processes.
