Many hosts now also show an entry in the process list labelled as “Other processes”.
What does “Other processes” actually represent?
Most important processes (i.e. suitable for deep monitoring) are listed in the Host details page, others that we see running on the host are listed when we drilldown to the complete process list, this including even technologies that we label as “Other”, yet there’s also this entry for “Other processes”.
I think those are processes that do not fall into any of the categories of detected processes:
So basically processes of unknown technologies, without TCP listening port, without significant CPU/Memory/Network usage) and without custom process detection rule definition.
But a clear definition in the documentation would be definitely appreciated.
It should include everything other that what is seen here in the list, basically would be processes of type/technology which are not supported by Dynatrace/OneAgent.
I am in the same situation where we are unable to get the detail from Dynatrace as it is showing the top consumed process is “other process”. We are forced to suggest some other tool to the client for getting the required details which are a very questionable thing. The client is asking why Dynatrace is not able to get the details which are intended to get from Dynatrace.
Kindly share if any document addressing “Other process” thing in Dynatrace
The “Other processes” unfortunately does not have any process group identification.
You can see running processes in the debug information when downloading Support archive from the agent (see processesSnapshot.log and other files), but might not be easy to figure out which process did the load. But at least you will have a clue what is running on the host without touching the host itself.
Many other monitoring tools I’ve seen also cannot identify the particular process generating load unless it is explicitly defined to be monitored. In Dynatrace you can do that with process group detection rules.
Actually, if anyone needs the info, you can find which processes are grouped under “Other processes” by downloading support archive for the host and looping through processesSnapshot.log in the diagnostic_files.zip.
Things have changed since 2020 Now dynatrace produces a json files instead of simple log file. Would you have any tips on how to find out unmonitored processes now ?
Hey brandizzi,
The files in question can be found within the support archive which you generate from the hosts page within Dynatrace. To generate them head over to the host page for the host you wish to look deeper into and select “Run oneagent diagnostics”. This can be found within the menu in the top right of the hosts page.
Once there, give a reason for creating the support archive and then start the process. It will take some time but once it is complete there will be an option to download and in the files downloaded you will find all sorts of information regarding your environment.
Is there way to get processesSnapshot.log to see some details of “Other” process as Dynatrace has stopped generating this log file under support archive instead its generating only json file.
“Other processes” have rather unfortunate name. It isn’t metric of other (aka not reported) process group instances, but rather “everything else” than reported PGIs.
So it can be CPU used by kernel, memory used for some caches or CPU/memory resources shared between different VM (so called ballooning).
At the moment Dynatrace doesn’t show those information. So I would have request for you: please create RFE and upvote it so would get traction. Or if someone already created one, please upvote that. Our PMs are deciding priorities of which functionalities implement first based on your votes.
