How to enable browser monitoring for the url with sso authentication?
The url doesn’t have username and password input but directly logins via sso
You can check Supported authentication methods in Synthetic Monitoring.
Best regards
@anton Thanks for your reply.
we are using smart pass card authentication, so we don’t use credentials for the sso login.
What can be done in this case?
I think that is not supported in Dynatrace Synthetics but lets wait anothers answers.
Best regards
Check if this thread helps you
https://community.dynatrace.com/t5/Synthetic-Monitoring/Multi-factor-authentication-for-synthetics/m-p/119500
