How to setup browser monitoring for sso enabled application urls, we are using smart card enabled sso so authentication is automated.
Thanks for the question. I see you got some answers here. I’m not sure this type of SSO would be suitable for Synthetic monitoring, as it requires a physical card, so it’s likely a work around would need to be provided, such as an API to get the token or some way to bypass it.
