How to expose dashboards created in One Agent using API?
I have used below curl command and generated file with “{“error”:{“code”:404,“message”:“feature disabled”}}”
curl -o DynatraceOneAgentInfrastructureDashboard.html https://xxxx.com/e/xxxxxx/api/config/v1/dashboards/8bdd3d50-5838-4a82-8a08-aa5a58670a3a? --header “Authorization: Api-Token fiFFmO7sQNKomLKPJob5n”
question is if this feature is disabled then what is the workaround?
Thanks & Regards,
Krunal Dave
Hi Krunal,
A dashboard itself cannot be exposed via the API but the timeseries metrics displayed in the dashboard can be exposed via the API. Please take a look at the documentation for the Timeseries API here.
Hope This Helps
NJ
Hi NJ
Thanks for your response.
Main goal for creating dashboard and exposed via API was to have all the data(for instance : JVM and Host related data) in one dashboard. if time series API is the only option then complexity will increase like joining multiple curl command for each time series matrix if one output is requested.
this is interim workaround but still question is why dashboard feature disabled in one agent(in AppMon latest v7.2 on wards this feature is still enable and ready to use).
Krunal Dave
