How to read CSV data from server to build a dashboard
I have scripts running on the server for capturing the data every 5 mins and wanted to read those files/capture data and present them in the dashboard.
Note: OneAgent is already installed on a server.
Regards
You could call the metrics api in your script to push the data to dynatrace.
Or you could convert it to a OneAgent Extension.
havent used API before , any example which can help?
The documentation I linked contains an Example that should fit your use case. Adding a new metric to an existing host.
