How to identify if the oneagent is Dynatrace managed or saas?
Hi
Could you please let us know how to identify if the Dynatrace deployment model is Managed or SaaS looking at the dynatrace oneagent console?
We have been provided test environment. We would like to know if it is deployed on Managed or SaaS.
Where can I check that in the console?
Thanks&Regards
Sangeetha
What do you mean by “Dynatrace oneagent console” ? There is no such thing as a console for oneagent.
If you mean the Dynatrace user interface, then if the domain is “.live.dynatrace.com” then the deployment model is SaaS. Otherwise, it is managed. Also the login screen differs between SaaS (two step login screen using proxy.dynatrace.com domain) and Managed (single login screen explicitely saying that it is dynatrace managed).
If you need to check it from the host, then look at the content of ruxitagentproc.conf file on the host and check the tenant value. If it is a GUID style name, it is managed, otherwise, it is SaaS.
Thank you for the response. Yes, I meant Dynatrace User Interface. Sorry for the confusion
That was helpful.
