How can I ingest alphanumerical values? date is only an example.
How can I display alphanumerical values in dashboards? Table, Textbox, or something else. Graph, I assume, would not work ;-). The workaround with writing a log file should work, but I cannot test this in my sandbox.
Is there a way to manipulate values when they come in? I.E. Value comes in → Script changes input “OK” to 1 → manipulated value is being used by Dynatrace.
It sounds like you want to ingest dimensions with your metric. Something like a status code “OK” would make sense here. But a timestamp here would not make sense, as it would increase the number of unique dimension key-value combinations and likely cause you to run into dimensionality limits.
The agent accepts data according to the metric ingest protocol. Adding a status code dimension may look like this:
Well, Its works, but i need few more information’s in my problems.
I want to see the host name and port number details as well in my problem ticket created.
/opt/dynatrace/oneagent/agent/tools/dynatrace_ingest concurrent.connection.small.metric
However I would like to pass few variable like hostname port number to see these details in Problem generated.
How can I do that
how should I see that hostname and port number that I am passing through my script.
