So, I collect a state (string=“OK”) and in the script I change for a (integer = 1). The unit type im using is State.
Now in Dynatrace I would like to transform again the metric to string. I have multiple applications with various states so its hard to follow/memorize all the tansformations String<-->Integer.
The challenge that Im facing now is to show the state in a human readable way. I have to create alerts and generate a reasonable dashboard.
Is it possible to convert the integer to string inside Dynatrace to generate friendly dashboards? (i have use cases with 10 states )
If (1.) its not possible I can use the problem app, but the state of application will be Red/Green.
In my example below I’m ingesting a metric thats random from 1-99 and has a device name as a dimension. You can then use partitions and a table view to display each dimension (in your case application) as being in a different state based on the last value.
