How to monitor Zookeeper and YARN in Dynatrace?
Hi, I need to monitor:
  • YARN
  • Zookeeper
I have reading the documentation, forum… and now I would like to know how to do it via JMX editor (if it’s really possible) or if there are other possible way, or, where I can find more information about it.
As I remember those processes are not monitored on transaction level. But if there are exposed JMX measures that are not available by default in Dynatrace for those processes you can search through available mbeans using JMX editor to find measures you need. It’s pretty simple task. Remember that you need full stack monitoring on host to enable JMX plugins :slightly_smiling_face:
Sure. Thank you, Sebastian!
