How to reference return from previous task
So what is the name in javascript when when you want to reference in the next task?
KR Henk
You will need to reference the task via the name/id.
The code to copy/paste:
var task_info = await fetch(`/platform/automation/v0.1/executions/${execution_id}/tasks/get_top10_error_logs`)
  var error_logs_task = await task_info.json()
