How to Remove "Ready-made" Dashboards ?
I’ve searched for a long time to delete the Ready-made Dashboards and I haven’t found anything, I even looked in the doc and it says you can’t delete them.
Is there really no way to delete them?
Manage dashboards - Dynatrace Docs
Thanks in advance.
Greetings,
This is a similar request to this one:
Disable Dynatrace preset Dashboards
There, @zietho from Dynatrace replied with a long explanation on why are we unable to hide this sort of stuff (back then, the topic was regarding Classic Dashboards).
He also posted a way of hiding said dashboards: not an easy nor pretty way, but it works (not quite sure it works on the latest dashboards, as I have not tested it yet).
As valuable as they are, I agree with you: we should be able to hide them (either latest or classic dashboards) in a clear and easy way.
Most users/clients do not like being forced to adopt something that might serve no one, only contributing to noise in dashboard lists and difficulting the accessability to other dashboards.
Unfortunately, you can not upvote the Product Idea since it was marked as “Indirectly addressed”.
Hello Pedro,
thank you for your reply.
I’m going to try the method you suggested, and I’ll also see if it’s possible to delete/hide dashboards via the API.
Bumping this one back, as although there is a trick to “Hide” preset classic dashboards, it doesn’t work with the new dashboards.
How could we do it with the new dashboards?
I’ve already tried using the api but unfortunately it doesn’t work. I don’t think there’s any way of doing it at the moment.
Agreed. We need this option.
Mid to end of september with a new document service version you should see two new endpoints:
1. makePrivate
2. makePublic
While these work for all documents. For Ready-made documents they practically hide them. Happy hiding ;).
And yes, later this year we gonna add a ready-made tab in the documents area in the settings for admins to do the same in the UI via a single icon click in the table.
After this we gonna extend ready-mades to be “shared”
 this means you can then not just simply hide them (step 1) but you can then also explicitly share them with users and groups instead of having them public.
Has this been deployed? I don’t see an option to change these to MakePrivate, unless i’m looking in the wrong spot.
sadly not yet, our service deployment are a bit (2+ weeks) behind currently.
I believe however, that it was included in v347, which we plan to deploy next week. If it was 348 then it would be in ~1-2 weeks time.
@zietho
Checked in a 1.347 tenant, and it’s not available.
