How to setup alert if ActiveGate goes down?
What is the way to get alert if ActiveGate goes down?
Hello @sujit_k_singh you can install OA and use the metric Host Availability State. See this link
@DanielS Thanks for your message, so that mean i need to install OA on ActiveGate server to monitor the status of AG. Right?
If licenses is not a problem, yes.
Best regards
Hi @sujit_k_singh,
What I did was enabling the location outage handling for the private synthetic locations under Settings/Web and mobile monitoring/Private Synthetic locations (you can bulk edit this also).
After that created a problem alerting profile which matches
Predefined: Contains events of type ‘Synthetic private location outage’
OR
Predefined: Contains events of type ‘Synthetic ActiveGate outage’ (which fits you)
and at last cretated an alerting via e-mail for that under integrations.
@Ldisztl92 Thanks for your message, i dont think this will work as out. I found better option for this i.e. ActiveGate metric “Active Gate - Communication - Agent Modules - Connected”
Tijust
