How to transfer synthetic monitors from one environment to another?
How can we transfer synthetic moniters from one environment to another
You have different alternatives:
  1. Manually using export / import from script view.
  2. Using Monaco V2, I would recommned this one.
Best regards
Hello Abid,
The easiest way is through the script tab, you can go to the synthetic monitor --> edit --> recorded clickpath --> then switch to script tab, you can download the json file and then use it in different environment while creating the monitor.
Islam
I would not suggest Monaco since  synthetic monitors are managed using classic configuration APIs and not Settings 2.0 schemas. Therefore, they do not use a schemaID d like Settings 2.0 configurations do.
I have worked with a client to recursively script out API calls to fetch all your synthetics and then post them into your new wanted environment
