Move synthetic tests from one tenant/environment to other
Is it possible to move synthetic tests from one tenant/environment to other via API or something?
Thanks…
Hi Akshay!
You can use Synthetic API to first fetch the monitor definitions on one environment in order to create the same monitors on the second environment.
Best regards,
Mateusz
Hi Mateusz,
Will this work for bulk movement? We have several tests to move.
Thanks…
Hi Akshay,
No, You have to do it one by one
Best,
Alonso
Hi Akshay,
I have this project that can help you with your migration GitHub - AlonsoDeCosio/dynatrace-sync-environments: Sync multiple Dynatrace environments · GitHub
Best
Alonso
Thats correct, we do the same thing from moving synthetics from one environment to the other without having to manually recreate it
