Dear Team ,
When I try to setup IBM-i AS400 plugin endpoint I am getting below error. I have no clue about the reason.
All necessary ports are reachable from our Activegate .
Any suggestion would be really helpful.
Akhil Jayendran
Dear Team ,
Akhil Jayendran
Hi @Akhil_Jayendran , did you completed the ODBC driver manager installation, as per documentation?
What is the OS for your AG which is hosting the extension?
Thanks.
Hi @dannemca ,
Thanks for your reply, Yes I have installed the ODBC.
XXXXX:/root # yum list installed |grep -i odbc
unixODBC.x86_64 2.3.1-14.el7 @rhel-7-server-rpms
unixODBC-devel.x86_64 2.3.1-14.el7 @rhel-7-server-rpms
XXXXX:/root # which isql
/bin/isql
XXXXX:/root # which odbcinst
/bin/odbcinst
And Os of my plugin activegate is Red Hat Enterprise Linux Server release 7.9
Akhil Jayendran
Do you mind to share your endpoint config settings from “Customize your extension” UI?
Hi @dannemca ,
Thank you for your reply.
This is fixed , Looks like our IBM-i AS400 able to accept only TLS connection . After configuring TLS connection plugin is working as expected .
Akhil Jayendran
