Dear All,
is there a way to detect the auto-defined cluster channels of the IBM MQ using the IBM MQ extension?
Babar
Dear All,
Babar
Hi @Babar_Qayyum ,
Unfortunately no, that is not supported at this time. They must be defined channels. Perhaps in the future after it is converted to EF 2.0.
Diego
Hello @diego_morales
Thank you for your comments. Is there any expected time period for the EF2.0 release?
Babar
The current plan is somewhere in the next 12 months.
FYI - I’ve opened an RFE to request this functionality be added to the IBM MQ extension:
