Import or Save Problem Card Page (Past or Present)
Is there a way to import or save Problems card page for a specific site (Past or Present)???
(see screenshot)
Hi there,
What do you exactly mean with “import or save”? Do you want to pull the problems out of Dynatrace and import in a different tool or perhaps an Excel document? To do that you could use the problem API:
You can also use this API to query the problems to filter a specific CI  / Tag etcetera.
KR.
Michiel
You can use the API as Michiel wrote in the previous comment. Personally, I also sometimes use an extension for Chrome browser called GoFullPage - Full Page Screen. With it you screen the full page to PDF and you can use that as a report - of course it’s workaround.
Radek
