Starting January 2026, we’re making two changes to how OTLP metrics are processed:
We are introducing an opt-in setting for “advanced OTLP metric dimensions” (docs).
The upside
after enabling it, OTLP metrics will support extended dimension capabilities, including Primary Grail Fields, higher cardinality limits, faster queries, and relaxed requirements for dimension names (including uppercase, or special characters like slashes).
The downside
after enabling this setting:
- OTLP metrics will no longer be automatically enriched with `dt.entity.service`. If you use this dimension in SLOs, alerts, or dashboards, you’ll need to update your queries.
- Mixed-case dimension keys are no longer normalized to lowercase. Previously, Metrics Classic required dimension names to be lowercase, so they were normalized on ingest (e.g. from
myCustomDimensiontomycustomdimension). With the toggle on, dimensions are stored exactly as your instrumentation sends them. DQL is case-sensitive, so existing queries that reference the lowercased form will return no data until updated.
Migrating Your Queries
1. Replace dt.entity.service filters
Current pattern:
timeseries sum(request_counter, rate: 1m),
<span class="prismjs _11c819w5 _2rko12b0 _1dqoglyw _1e0c1txw _vwz4gktf _1reo1wug _o572qvpr _1eimjvyg _bfhk187e _syazi7uo _1ozdn7od _7xinn7od _t7aun7od _r28du2gc _tajqu2gc _1ohiu2gc _m802u2gc _i6ntu2gc _1w2xu2gc _1hmyegat _vblregat _vbulegat _196q1xv3 _1vbw1xv3 _1v9c1xv3 _1srnt0uh _18r6myb0 _vyvc1n1a _1d4j1y44 _1f8gstnw _1pzyb3bt _ra6gsb9t _13cdh2mm _1pp0126e _zvy9f705 _qcxof705 _qzn01a66 _j0l11wug _1weckb7n _1na21hna _vsnzgrf3 _x7c815vq _lh0y15vq _1m3815vq _qk1e15vq _12l6ysn8 _uga3ysn8 _mx8b7mnp _1kr87mnp _xo19t94y _1bemt94y _nalpstnw _151dstnw _1exb1q9c _1hgu1q9c _1mgnt94y _nhket94y _h909i8nm _scgayz1z _ipl81e17 _40uk1l04 _i81p1a66 _1gx21e5h _1ls01ule _vm2c1rh5 _12ok1rh5 _rude1ule _1q16glyw _1io6glyw _juomusic _lcwuusic _pyovu2gc _ccm6u2gc _1ascu2gc _1yuau2gc _xr0w1a66 _4io21a66 _euyxusvi _cahfusvi _zhnuidpf _1amdidpf _mbgc124n _bu7z124n _131n1giz _gy101giz _1wfuwrk5 _16kzwrk5 _9kk3wu06 _cjus1w1g _9k2r1m30 _nhmw1m30 _yl021m30 _eihtd5cb _t9zbd5cb _mqok1w1g _3hsg1w1g _i7ngn7od _9wu1fb2s _1xcoh55r _1t36i7uo _137bh55r _1k7di7uo _97li16jw _12nh9lu1 _1g0517qg _i2igqmo9 _326zi7uo _113p1rpy _1n6t16jw _tgu817qg _1k4716jw _g0lxi7uo _ys4e1rpy _7gp8h55r _1yvqqmo9 _1vwwqmo9 _1rjuqmo9 _1v0lh55r _wmyy17qg _748n17qg _1mfn17qg _1d7e17qg _p2vr17qg _19o6qmo9 _kxov17qg _1np517qg _m2f517qg _1b9t16jw _1tq616jw _1rd216jw _1pbk16jw _k3li16jw _13zt1rpy _2g12fb2s _k86bqmo9 _b5iy1rpy _gti31rpy _1f0g16jw _9d3e17qg _qdia16jw _72uv16jw _13dgkb7n _1707efft _1i3h1txw _16noidpf _h4fuidpf _pp6yidpf _1g4tidpf _11wmidpf _1bx8idpf" data-testid="renderer-code-block" data-ds--code--code-block="" data-code-lang=""><code class="language-"><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-2"> filter: { dt.entity.service == "SERVICE-4E5FC455D32B2912" }</span></code></span><span class="prismjs _11c819w5 _2rko12b0 _1dqoglyw _1e0c1txw _vwz4gktf _1reo1wug _o572qvpr _1eimjvyg _bfhk187e _syazi7uo _1ozdn7od _7xinn7od _t7aun7od _r28du2gc _tajqu2gc _1ohiu2gc _m802u2gc _i6ntu2gc _1w2xu2gc _1hmyegat _vblregat _vbulegat _196q1xv3 _1vbw1xv3 _1v9c1xv3 _1srnt0uh _18r6myb0 _vyvc1n1a _1d4j1y44 _1f8gstnw _1pzyb3bt _ra6gsb9t _13cdh2mm _1pp0126e _zvy9f705 _qcxof705 _qzn01a66 _j0l11wug _1weckb7n _1na21hna _vsnzgrf3 _x7c815vq _lh0y15vq _1m3815vq _qk1e15vq _12l6ysn8 _uga3ysn8 _mx8b7mnp _1kr87mnp _xo19t94y _1bemt94y _nalpstnw _151dstnw _1exb1q9c _1hgu1q9c _1mgnt94y _nhket94y _h909i8nm _scgayz1z _ipl81e17 _40uk1l04 _i81p1a66 _1gx21e5h _1ls01ule _vm2c1rh5 _12ok1rh5 _rude1ule _1q16glyw _1io6glyw _juomusic _lcwuusic _pyovu2gc _ccm6u2gc _1ascu2gc _1yuau2gc _xr0w1a66 _4io21a66 _euyxusvi _cahfusvi _zhnuidpf _1amdidpf _mbgc124n _bu7z124n _131n1giz _gy101giz _1wfuwrk5 _16kzwrk5 _9kk3wu06 _cjus1w1g _9k2r1m30 _nhmw1m30 _yl021m30 _eihtd5cb _t9zbd5cb _mqok1w1g _3hsg1w1g _i7ngn7od _9wu1fb2s _1xcoh55r _1t36i7uo _137bh55r _1k7di7uo _97li16jw _12nh9lu1 _1g0517qg _i2igqmo9 _326zi7uo _113p1rpy _1n6t16jw _tgu817qg _1k4716jw _g0lxi7uo _ys4e1rpy _7gp8h55r _1yvqqmo9 _1vwwqmo9 _1rjuqmo9 _1v0lh55r _wmyy17qg _748n17qg _1mfn17qg _1d7e17qg _p2vr17qg _19o6qmo9 _kxov17qg _1np517qg _m2f517qg _1b9t16jw _1tq616jw _1rd216jw _1pbk16jw _k3li16jw _13zt1rpy _2g12fb2s _k86bqmo9 _b5iy1rpy _gti31rpy _1f0g16jw _9d3e17qg _qdia16jw _72uv16jw _13dgkb7n _1707efft _1i3h1txw _16noidpf _h4fuidpf _pp6yidpf _1g4tidpf _11wmidpf _1bx8idpf" data-testid="renderer-code-block" data-ds--code--code-block="" data-code-lang=""><code class="language-"></code></span>
New pattern:
Since dt.entity.service was calculated from SDv2 service detection rules, you can filter using the same underlying attributes. For Kubernetes workloads:
</span><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-3"> k8s.workload.name == "productcatalogservice"
</span><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-4"> and k8s.namespace.name == "astroshop"
</span><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-5"> and k8s.cluster.uid == "28d34e2d-2420-4ca7-9d3a-4fc69cac077b"
</span><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-6"> }</span></code></span>
For non-Kubernetes deployments, use service.name:
<span class="" data-ds--code--row="" data-testid="renderer-code-block-line-1">timeseries sum(request_counter, rate: 1m), <br> </span>
These attributes must already be present as resource attributes on your OTLP metrics. Dynatrace does not automatically add them. OpenTelemetry instrumentation must send them. If you’ve customized your SDv2 detection rules, use the same custom attributes in your queries.
2. Update mixed-case dimension references
If your instrumentation emits camelCase or PascalCase dimension keys, update queries to match the original casing.
Before (Metrics Classic forced lowercase):
timeseries sum(http_requests),
<span class="prismjs _11c819w5 _2rko12b0 _1dqoglyw _1e0c1txw _vwz4gktf _1reo1wug _o572qvpr _1eimjvyg _bfhk187e _syazi7uo _1ozdn7od _7xinn7od _t7aun7od _r28du2gc _tajqu2gc _1ohiu2gc _m802u2gc _i6ntu2gc _1w2xu2gc _1hmyegat _vblregat _vbulegat _196q1xv3 _1vbw1xv3 _1v9c1xv3 _1srnt0uh _18r6myb0 _vyvc1n1a _1d4j1y44 _1f8gstnw _1pzyb3bt _ra6gsb9t _13cdh2mm _1pp0126e _zvy9f705 _qcxof705 _qzn01a66 _j0l11wug _1weckb7n _1na21hna _vsnzgrf3 _x7c815vq _lh0y15vq _1m3815vq _qk1e15vq _12l6ysn8 _uga3ysn8 _mx8b7mnp _1kr87mnp _xo19t94y _1bemt94y _nalpstnw _151dstnw _1exb1q9c _1hgu1q9c _1mgnt94y _nhket94y _h909i8nm _scgayz1z _ipl81e17 _40uk1l04 _i81p1a66 _1gx21e5h _1ls01ule _vm2c1rh5 _12ok1rh5 _rude1ule _1q16glyw _1io6glyw _juomusic _lcwuusic _pyovu2gc _ccm6u2gc _1ascu2gc _1yuau2gc _xr0w1a66 _4io21a66 _euyxusvi _cahfusvi _zhnuidpf _1amdidpf _mbgc124n _bu7z124n _131n1giz _gy101giz _1wfuwrk5 _16kzwrk5 _9kk3wu06 _cjus1w1g _9k2r1m30 _nhmw1m30 _yl021m30 _eihtd5cb _t9zbd5cb _mqok1w1g _3hsg1w1g _i7ngn7od _9wu1fb2s _1xcoh55r _1t36i7uo _137bh55r _1k7di7uo _97li16jw _12nh9lu1 _1g0517qg _i2igqmo9 _326zi7uo _113p1rpy _1n6t16jw _tgu817qg _1k4716jw _g0lxi7uo _ys4e1rpy _7gp8h55r _1yvqqmo9 _1vwwqmo9 _1rjuqmo9 _1v0lh55r _wmyy17qg _748n17qg _1mfn17qg _1d7e17qg _p2vr17qg _19o6qmo9 _kxov17qg _1np517qg _m2f517qg _1b9t16jw _1tq616jw _1rd216jw _1pbk16jw _k3li16jw _13zt1rpy _2g12fb2s _k86bqmo9 _b5iy1rpy _gti31rpy _1f0g16jw _9d3e17qg _qdia16jw _72uv16jw _13dgkb7n _1707efft _1i3h1txw _16noidpf _h4fuidpf _pp6yidpf _1g4tidpf _11wmidpf _1bx8idpf" data-testid="renderer-code-block" data-ds--code--code-block="" data-code-lang=""><code class="language-"><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-2"> filter: { httpmethod == "GET" and customertier == "gold" }</span></code></span>
After (toggle on, original casing preserved):
<span class="prismjs _11c819w5 _2rko12b0 _1dqoglyw _1e0c1txw _vwz4gktf _1reo1wug _o572qvpr _1eimjvyg _bfhk187e _syazi7uo _1ozdn7od _7xinn7od _t7aun7od _r28du2gc _tajqu2gc _1ohiu2gc _m802u2gc _i6ntu2gc _1w2xu2gc _1hmyegat _vblregat _vbulegat _196q1xv3 _1vbw1xv3 _1v9c1xv3 _1srnt0uh _18r6myb0 _vyvc1n1a _1d4j1y44 _1f8gstnw _1pzyb3bt _ra6gsb9t _13cdh2mm _1pp0126e _zvy9f705 _qcxof705 _qzn01a66 _j0l11wug _1weckb7n _1na21hna _vsnzgrf3 _x7c815vq _lh0y15vq _1m3815vq _qk1e15vq _12l6ysn8 _uga3ysn8 _mx8b7mnp _1kr87mnp _xo19t94y _1bemt94y _nalpstnw _151dstnw _1exb1q9c _1hgu1q9c _1mgnt94y _nhket94y _h909i8nm _scgayz1z _ipl81e17 _40uk1l04 _i81p1a66 _1gx21e5h _1ls01ule _vm2c1rh5 _12ok1rh5 _rude1ule _1q16glyw _1io6glyw _juomusic _lcwuusic _pyovu2gc _ccm6u2gc _1ascu2gc _1yuau2gc _xr0w1a66 _4io21a66 _euyxusvi _cahfusvi _zhnuidpf _1amdidpf _mbgc124n _bu7z124n _131n1giz _gy101giz _1wfuwrk5 _16kzwrk5 _9kk3wu06 _cjus1w1g _9k2r1m30 _nhmw1m30 _yl021m30 _eihtd5cb _t9zbd5cb _mqok1w1g _3hsg1w1g _i7ngn7od _9wu1fb2s _1xcoh55r _1t36i7uo _137bh55r _1k7di7uo _97li16jw _12nh9lu1 _1g0517qg _i2igqmo9 _326zi7uo _113p1rpy _1n6t16jw _tgu817qg _1k4716jw _g0lxi7uo _ys4e1rpy _7gp8h55r _1yvqqmo9 _1vwwqmo9 _1rjuqmo9 _1v0lh55r _wmyy17qg _748n17qg _1mfn17qg _1d7e17qg _p2vr17qg _19o6qmo9 _kxov17qg _1np517qg _m2f517qg _1b9t16jw _1tq616jw _1rd216jw _1pbk16jw _k3li16jw _13zt1rpy _2g12fb2s _k86bqmo9 _b5iy1rpy _gti31rpy _1f0g16jw _9d3e17qg _qdia16jw _72uv16jw _13dgkb7n _1707efft _1i3h1txw _16noidpf _h4fuidpf _pp6yidpf _1g4tidpf _11wmidpf _1bx8idpf" data-testid="renderer-code-block" data-ds--code--code-block="" data-code-lang=""><code class="language-"><span class="" data-ds--code--row="" data-testid="renderer-code-block-line-2"> filter: { httpMethod == "GET" and customerTier == "gold" }</span></code></span>
Audit notebooks, dashboards, SLOs, and alerts for any dimension keys that your instrumentation sends in mixed case. If you’d rather keep lowercase queries, normalize at the source: in your instrumentation, in an OpenTelemetry Collector processing pipeline, or via an OpenPipeline rule.
What You Gain
Once enabled, OTLP metrics support:
- Primary Grail Fields as dimensions: Use fields like
k8s.namespace.name,aws.account.id,azure.subscription,gcp.project.idfor filtering, grouping, and correlation. - Higher cardinality limits: Significantly increased limits compared to the previous protocol.
- Faster query performance: Optimized for Grail.
- Special characters in dimensions: Slashes and other characters now supported.
- Original dimension casing preserved: Mixed-case keys (e.g.,
myCustomDimension) are stored as sent, instead of being force-lowercased to match Metrics Classic rules. See migration note above.
These dimensions enable downstream capabilities like pipeline routing, bucket assignment, security context, cost allocation, and segment-based alerting, provided your instrumentation sends the relevant resource attributes.
Supported Primary Grail Fields
aws.account.idaws.regionazure.locationazure.resource.groupazure.subscriptiongcp.project.idgcp.regionk8s.cluster.namek8s.namespace.namedt.host_group.id
Timeline
February 2026: Opt-in available
- A toggle appears in Settings: Enable advanced OTLP metric dimensions
- Enabling the toggle removes
dt.entity.servicefrom OTLP metrics - Enabling the toggle preserves original dimension key casing (no more forced lowercase)
- Test in lower environments before enabling in production
Ongoing rollout
- New tenants get the toggle enabled by default
- Existing tenants get it enabled when they opt into Phase 3, or at any time via the toggle
- No forced migration for existing tenants; you stay on the previous behavior until you opt in
- Update your queries, SLOs, alerts, and dashboards before enabling
Need Help?
If you have questions or need assistance migrating your queries, contact your Dynatrace support team or reply to this post.
