Summary
The Dynatrace Entities API (/api/v2/entities) and Grail expose an isEnabled property for Synthetic Monitors. This value is also displayed in the latest Synthetic app.In some environments, the isEnabled property may not match the monitor’s actual enabled or disabled state. This article explains how to identify this behavior and restore the correct value.
Problem
You may observe that a Synthetic Monitor displays a different enabled status depending on which interface or API is used.Examples include:
- The monitor is shown as enabled in the Classic Synthetic app but disabled in the latest Synthetic app.
- The
isEnabledproperty returned by the Entities API (/api/v2/entities) does not match the monitor configuration. - Grail reports an incorrect
isEnabledvalue. - Automation, scripts, or integrations relying on the
isEnabledproperty return unexpected results.
A bug caused incorrect values to be stored for the isEnabled property of some Synthetic Monitors. This behavior affects:
- Entities API (
/api/v2/entities) - Grail
- The latest Synthetic app
The following sources continue to display the correct status:
- Classic Synthetic app
- Synthetic Monitors API (
/api/v1/synthetic/monitors)
Affected Versions
The issue was fixed in Cluster version 1.298. Existing monitor configurations remain correct and monitors continue to execute normally. However, monitors already affected by this behavior require manual correction to update the value displayed in Grail, the latest Synthetic app, and the Entities API
Resolution
For each affected Synthetic Monitor:
If the Monitor Is Enabled
- Disable the monitor.
- Save the change.
- Re-enable the monitor.
- Save the change again.
If the Monitor Is Disabled
- Enable the monitor.
- Save the change.
- Disable the monitor again.
- Save the change.
Toggling the monitor status forces the correct isEnabled value to be updated and reflected in:
- Entities API (
- Latest Synthetic app
What’s next
If none of the previous steps resolved the issue, then open a chat and provide a link to the affected monitor and mention this article.
Related reading
Synthetic Troubleshooting Map
Synthetic app
Monitored Entities API
