Can we have a feature to completely disable synthetic monitoring while maintenance duration?
While setting up maintenance window for a synthetic monitor, we have 3 feature i.e “DETECT_PROBLEMS_AND_ALERT” , “DETECT_PROBLEMS_DONT_ALERT” , “DONT_DETECT_PROBLEMS”. However can one more feature be added as “Do_No_Monitor”, where the script is completely disabled and we do not require any kind of logging in to the website?
At the moment, you can do it through the API, as discussed here:
Hi Abbas,
The implementation of the “Maintenance window” feature has already started.
For now, please use the API to enable/disable chosen monitors.
Tomek
