Record Synthetic monitors in timeframe?
Hello all,
is it possible to record Syntethic monitors in fixed timeframe from Monday to Friday from 5:00AM to 10:00AM
You can use Maintenance windows to stop monitors executing during certain periods of the day. When creating the maintenance window enable the disable Synthetic Monitor execution slider. Alternatively, you can use the Synthetic Monitors API to enable and disable the monitor.
Thank you Hannah, you are the best! :wink:
