"Indeterminable error name" javascript errors occur after activate Angular framework
After activating Support for XmlHttpRequest and AngularJs and Angular in the settings for the application the javascript errors for Indeterminable error name occurs more than thousend times within two hours.
The angular script is minified so the stacktrace is not helping to analyse the problem. The application is Angular8.
When you are enabling support for angular framework there is warning that application has to be compiled in defined way, or has to have DT JS invocation implemented. Did you make it?
Thanks for the input. I will check with our FE Devs and see if this is still a problem for them.
