Is there any documention on how to create or integrate an esbuild plugin using app toolkit configuration ?
Ref:
https://developer.dynatrace.com/develop/app-toolkit/configuration/
Ref:
Hi @DaveOps , may I ask what is your specific use case?
Hi there
At the moment, it’s not possible to extend the build pipeline for your Dynatrace Apps.
Hi imsingh,
Is it still not possible today to configure the dt-app App Toolkit with esbuild plugins?
My use case: be able to use environment variables defined in my .env file in the frontend by using esbuild which during build time will substitute environment variables.
