Infrastructure Only
The customer was told that if you enable infrastructure only mode instead of full stack you can avoid restarting servers/processes after the one agent update, is this true?
Yes, this is true.
Ok thank you so much!
infrastructure monitor also uses less licenses and is a really good solution for servers such as SQL that use a large amount of RAM
Ok. Also, is this whether or not auto-injection is enabled? For the one agent update.
Auto injection is separate from Oneagent Upgrades. Auto injection is part of full stack monitoring where Dynatrace Oneagent Injects java script code for RUM monitoring.
