OneAgent in Infrastructure Monitoring mode automatically injects into processes to be able to monitor backing services written in Java and runtime metrics for supported languages. If the auto-injection is disabled for individual hosts, related vulnerabilities can’t be assessed.
To enable auto-injection in Infrastructure Monitoring mode, you need to enable runtime metrics.
To enable runtime metrics
- From the Dynatrace menu, select Settings > Monitoring > Monitored technologies.
- In the list of supported technologies, search for the Java/.NET/Node.js/Golang/PHP runtime metrics + WebServer metrics in Infrastructure Mode entry.
- Select the pencil icon to edit it and then enable it.
- Restart all processes on your infrastructure-monitored hosts.
For details, see Process injection in Infrastructure Monitoring mode.
