We’re currently exploring the integration of Azure Function App and API Logs to send to Dynatrace. Since our environment is based on a Linux App Service Plan and want to ingest logs using ActiveGate, if you could help guide us or share any documentation or best practices specific to Linux-based setups for this integration that would be really helpful.
Documentation for ingesting logs using API - Log ingestion via API — Dynatrace Docs
If you want to do it using the ActiveGate, make sure the clients using the ActiveGate log ingestion API will trust the certificate on the ActiveGate (you may want to deploy you own certificate)
Thanks for your quick response. is it possible to give us much more comprehensive documentation. That would be really helpful.
