Monitor Azure API Management Telemetry with Dynatrace
Summary: This thread explains options for ingesting Azure API Management telemetry into Dynatrace. It describes supported data paths and how to view API gateway logs and metrics.
How can I stream Azure API Management traces/logs into Dynatrace? I saw that there’s an extension (Azure API Management Service monitoring - Dynatrace Docs) however it is not what I’m looking for.
Azure log forwarding :
