Hello community, the deployment of this extension has been carried out on some hosts with Linux operating systems, but I still don’t see any information coming from this extension.
I have reproduced this process in a test environment to see how it resolves before going into production.
Upon reviewing the documentation, it appears that I need to install ActiveMQ on Linux to prepare this host and enable this extension to function.
My questions are: 1. Should I configure something on my machine (host) before setting up the ActiveGate and the extension?
Should I update the JAVA SDK and install ActiveMQ Classic on my host before starting the process with Dynatrace, and if so, how should I configure the communication ports?
And finally, simply put, what would be the solution to view data from a Linux machine through the ActiveMQ Classic extension?
