Apache ActiveMQ Classic does not connect with Linux Operating System
hello group
I have a problem with the Apache ActiveMQ Classic extension.
I tell you that we have already completed all the prerequisites and we cannot see metrics for Linux operating systems.
Is there something that needs to be done?
Are there any ports to keep in mind?
I believe that the best thing to do would be to open up an interaction in the chat window while using Dynatrace, where they can help guide you through downloading active gate logs / using our tools to look into the back end of your tenant. I would check for the metrics page and see if there’s any data attached to the metrics or not.
