I’m a bit confused what the state of support for ActiveMQ Artemis and ActiveMQ is. Based on some forum posts here and also my experience ActiveMQ Artemis is not fully supported (that is JMX metrics via built-in plugins). There are custom JMX plugins that fetch AMQ Artemis metrics, though.
On the other hand on the Dynatrace Hub we can find both flavours as supported by Dynatrace:
On the Queues screen then there is a ActiveMQ queue (which in reality is a ActiveMQ Artemis Queue) which shows no queue metrics, but reminds me to activate the ActiveMQ JMX plugin (which is enabled but doesn’t provide any data since it is ActiveMQ Artemis)
This seems a bit inconsistent and like incomplete support, relying on community AMQArtemis plugins and a little “bit” official support. So my questions:
- what is needed to detect ActiveMQ Artemis as technology correctly?
- is there an official support for AMQ Artemis? Are metrics from AMQArtemis collected via the “normal” AMQ JMX extension? Should the ActiveMQ JMX plugin be enhanced?
- How can AMQArtemis metrics on the Queues screen be displayed the same way as for “normal ActiveMQ” (seems that this built in page for AMQ provides more queue details than for AMQArtemis)
Same question here and what to do in order to get metrics in queues and broker section. Documentation seems incomplete. A blog post would be nice for clarification.
Hi @r_weber, thanks for your questions - please see my answers below:
What is needed to detect ActiveMQ Artemis as technology correctly?
ActiveMQ Artemis monitoring is an out-of-the-box capability of Dynatrace – no extension is needed here. It seems that in your case ActiveMQ Artemis cannot be detected (further investigation via our Support team would be needed here)
We currently don’t offer a plugin for ActiveMQ Artemis. This might change in the future. However, please note that Apache suggests Micrometer as metrics provider not JMX. Follow up reading: Metrics
ActiveMQ Artemis metrics are currently not available, but this might change in the future.
