Tabs missing on ActiveMQ items
We’re trying to monitor queues with ActiveMQ, The hosts are showing but they’re missing multiple tabs.
None of our ActiveMQ instances are showing these tabs -
* ActiveMQ metrics
* Queues metrics
* Jetty metrics
Does anyone have suggestions about what needs to be fixed/changed for this data to be populated in Dynatrace?
Metrics for ActiveMQ and Jetty are gathered via JMX. So as long as you didn’t disable those modules the metrics should appear after a restart of the JVM, once the agent is installed.
Those metrics will be on the process not host level though.
