Dear all,
one of our partners’ customer would like to integrate IBM qRadar with Dynatrace managed in a way that Dynatrace cluster/oneagent sends their logs an health statuses to qRadar.
We found this soultion, I’m not sure if it’ s possible. Dynatrace and QRadar: Automate Workflows with n8n
Can You help me with this?
Thanks a lot
Kind regards
Peter
Managed cannot send any cluster logs to external destionation. You are free to build it by yourself using other tools. Same applies for OneAgent logs, but you can at least collect the OneAgent log files using OneAgent (with costs incurred).
We’ve built a Dynatrace QRadar integration for ingesting Dynatrace audit log data into QRadar utilizing Dynatrace API only and QRadar native means. This works for both Managed and SaaS.
Btw - SaaS has now also the new Grail audit log, which contains much more information than the Audit log api.
